Can’t seem to get the eyes transparent.
Forum Archive Can’t seem to get the eyes transparent.
  • #13349
    babyshakespeare
      I’m using blender 2.92, and I can’t seem to get the eyes to view as transparent in the material viewport, and even eevee rendered view. They do work in Cycles however.
      I’ve tried enabling screen space reflections, and refraction in the eevee settings but to no avail.
      I’m sure the answer is obvious, but for some reason I’m unable to see it.
      EDIT: I seem to have fixed it, I had to go into the Vonnbots2.78 blend file, and change the Transparency mode on the glass material to Alpha Blend.
      #62493
      Wayne Dixon
        Glad you solved you issue BabyShakespeare, but there are 2.8+ versions of of these files 😉
        https://blog.cgcookie.com/animation-bootcamp-2-8-compatible-files/
        In addition to the material fixes, there are some python api changes in the script and better organisation with collections too.
        #62494
        babyshakespeare
          Oh dang, I didn’t even see those! thank you!
        • The topic ‘Can’t seem to get the eyes transparent.’ is closed to new replies.
