Can’t Find the Displacement in the panel
Forum Archive Can’t Find the Displacement in the panel
  • #7050
    Nathan Foster
      I’m following along with the tutorial. In the render properties,  I changed the feature set from “supported” to “experimental,” but I don’t see the displacement
      option in the object data panel. Is this feature no longer there, or is it an addon?
      #26432
        Oops I think they moved the location for this option in a recent version of Blender. Now if you have the “Experimental” feature set enabled, in the material tab of the properties panel at the bottom in the “Settings” dropdown, you’ll see the Displacement option where you can change from Bump to True.
      • The topic ‘Can’t Find the Displacement in the panel’ is closed to new replies.
