Can’t find my Fonts in Blender
Forum Archive Can’t find my Fonts in Blender
  • #12036
    gavrimar
      Hey guys!
      downloaded & installed some fonts from google.
      Word sees them, inkscape see’s them, Blender doesn’t.
      Checked in the preferences-> File paths -> data
      the fonts are set to the correct adress C:\Windows\Fonts\
      What am I missing?
      p.s-I am not afraid to use Bfont in ALL OF MY WORK until my probelm gets the attention it deserves.
      j.k, thanks in advance!
      #57188
      Wayne Dixon
        Hi gavrimar,
        From what I understand the setting in the preferences is only a shortcut to the location so when you click on the folder icon in the Font panel, that is where it opens the file browser.
        Blender does not actually load them into memory because it will use that memory for more important things, like your cool 3d geometry.
        You will still need to load the fonts you want to use into the file.
        You can load more than 1 font at a time but you need to be weary of how Blender removes unused data-blocks.  If a data-block doesn’t have any users when the file is closed it will not be kept in the file anymore (so click the shield to make it stay)
        If you find that you always need the same fonts you can load them into your default file, click the shield and then save that file as the new default.  That way they are always there when you open up a fresh file.
        Hope that helps.
        #57189
        gavrimar
          All those tips are great!
          It’s weird that Blender needs to load fonts even if they are installed in the system, but I guess the default-file tip solves that.
          Thanks mate!
        • The topic ‘Can’t find my Fonts in Blender’ is closed to new replies.
