Can’t do the bevel at the center of the hub
Forum Archive Can’t do the bevel at the center of the hub
  • #17119
    Kyle Dunlop
      I have tried both 3.6.5 and 4 and i can get it to get the bevel tool with ctrl b but it either doesn’t do anything or it gives me all sorts of weird geometry
      #82376
        Hi Kyle @rudun ,
        If it doesn’t seem to do anything, you probably have Clamp Overlap enabled and if it gives weird Geometry (probably after disabling the Clamp Overlap), usually your Bevel Width is too large.
        #82377
          And don’t forget to go into edit mode, select it all and M to merge by distance, in case you have doubled vertices.
          #82378
          Chunck Trafagander
            Hey @rudun, if you are still running into issues would you also be able to provide screenshots or a quick video? That would really help us troubleshoot what’s going on.
            Thanks!
            Chunck 🙂
          • The topic ‘Can’t do the bevel at the center of the hub’ is closed to new replies.
