cant create geometry
Forum Archive cant create geometry
  • #6413
    Ang Kok Hoe
      hi, im using blender 2.78c
      but i cant create any geometry in edit mode by clicking Ctrl+left/right click
      may i know any suggestion to do so?
      #25372
      davidboothe
        @kokhoe20 I was running into the same issue. If you don’t have vertex select mode enabled, then you won’t see the vertex that is created. By default, I had edge selection mode enabled.
        #25373
        jevlin
          Ah, thank you so much, I had the same issue and changing to vertex mode solved the problem.
        • The topic ‘cant create geometry’ is closed to new replies.
