Can’t access the bones in weight paint mode (V3.1)
Forum Archive Can’t access the bones in weight paint mode (V3.1)
  • #15273
    James Treweek
      Hi,
      I’ve tried several times (in 3 different tutorials!) to follow exactly what Wayne is doing to be able to select the bones in weight paint mode and I’m unable to make it work.
      He mentions here, something about it being different after Blender 2.8 so am I unable to do this because I’m using 3.1?
      Is there a different way to access them (efficiently).
      Many thanks.
      #74765
      James Treweek
        Ah!! It’s SHIFT-select……..ok…..back to work……
        #74766
          Just in case, there’s also this annoying toggle in my opinion. If you go to Edit, the option before Preferences that says “Lock Object Modes”. If that is checked, it locks you from being able to mix modes, so bones aren’t selectable when you’re weight painting. I always have that unchecked because I like mixing object modes.
          #74767
          James Treweek
            Thank you. Yes, I’ve toggled that off….but I confess, by brain isn’t entirely clear what the difference is yet!
            I’m sure everything will became clear over time and with practise.
            I already feel I know SO much more than a month ago.
            #74768
            Adrian Bellworthy
              Having the ‘Lock Object Modes’ turned off, simply means when you select an object it will enter the mode that you left it in.
              For example: If you have the armature selected and are in pose mode, then select the strut, when you select the armature again, it will go straight into pose mode.
              Its convenient in this case because you can have the strut in object mode and the armature in pose mode.
              With it turned on the strut and armature can only be in the same mode, in this case object mode, as pose mode is not available for geometry.
              However, you cannot be in edit mode and select another object. And you can only change the mode on the active object.
              Which is why the strut is selected last making it active, and able to change to weight paint mode.
              Hope this makes sense!
              #74769
              James Treweek
                Thank you! (Sorry, I missed this yesterday)
              • The topic ‘Can’t access the bones in weight paint mode (V3.1)’ is closed to new replies.
