Can you use Principled Shader in 2.79 instead of CGC_PBR shader?
Forum Archive Can you use Principled Shader in 2.79 instead of CGC_PBR shader?
  • #6739
    Michael Wanyoike
      Will the results be the same?
      #25890
      Jonathan Lampel
        You sure can! The results will be the same for all intents and purposes.
        #25891
        maurotron
          I was wondering the same, I think its ok to use the principled shader.
        • The topic ‘Can you use Principled Shader in 2.79 instead of CGC_PBR shader?’ is closed to new replies.
