can someone explain what noise basis and distortion do in the displacement modifier i provided an example
Forum Archive can someone explain what noise basis and distortion do in the displacement modifier i provided an example
  • #12498
    man5678
      https://imgur.com/a/GBRg0hy here is the example i feel so stupid for not knowing. is it because the noise determines the pattern and distortion determines the shape?
      #59320
        Hi man, don’t feel stupid for not knowing this!
        The noise basis is the ‘start’ or basis noise. The distortion distorts that noise. The easiest way to see what is happening is by looking mostly at the Preview and set the Amount (which is the amount of distortion of the basis noise) to 0, so you only have the basic noise (try the different noise patterns that are available) and then slowly increase the distortion Amount to se how the noise gets distorted:
        #59321
        man5678
          i did some experimenting and it seems like when you increase the distortion the shape changes (i guess it gets distorted) is this correct?
          #59322
          man5678
            #59323
              Yes, indeed, the basis noise gets distorted according to the noise pattern/type, specified in the distortion field.
              #59324
              man5678
                thanks for the help 🙂
                #59325
                silentheart00
                  @man5678 I suggest trying a different texture like a wave texture to see the effects of the distortion more clearly.  Noise is, well, noisy, so it’s difficult to tell.  But I think your understanding is correct.
                • The topic ‘can someone explain what noise basis and distortion do in the displacement modifier i provided an example’ is closed to new replies.
