I’m new to Blender, but I have used Lightwave. I’ve seen a weightmap used with instancing, like where some plants should grow. But I’ve never seed a weightmap used to control a texture using either procedural or image maps. Why is that? Can it be done? thanks
As far as I know in Blender weight map just defines a vertex group.
I haven’t seen vertex groups as a way to control textures but you can do that with with alpha maps (black and white all the gradients in between) with either ones created procedurally or painted/created by yourself.
In Blender there are many ways to do one thing. So what are you trying to do? Because there might be another way you can achieve the result you’re after.
Author
The topic ‘Can I use a weightmap to isolate a texture?’ is closed to new replies.
