Broken Course
Forum Archive Broken Course
  • #20872
    Matthew Kuzmicz
      The videos are not loading for some reason. Can this be fixed? Someone else had this issue on March 10th, and it seems that the issue hasn’t been resolved since then.
      #97450
        Hi Matthew @mkuzmicz ,
        The Course is fine.
        If you are facing issues, try and clear your Browser Cache. That usually does the trick.
        #97451
          Or use a different browser, that also works most of the time. Browsers can be finicky.
          #97452
          Matthew Kuzmicz
            I switched browsers and that did the trick. Appreciate all the responses.
          • The topic ‘Broken Course’ is closed to new replies.
