blender palette colors do not save colors well in Blender 4.2
Forum Archive blender palette colors do not save colors well in Blender 4.2
  • #18359
    r h
      It saves any color as black. I went back to Blender 4.1 to prevent this.  But its better to go to blender 4.0 as a bug with the compositing will give you trouble in the future. (during the bubble exporting segment)
      #87679
      Paul Caggegi
        Ooof yeah. This is annoying me to NO END. It will add a swatch, but then you have to click and drag the color into it.
        #87680
        Grady Pruitt
          that is SOOOOO not intuitive! I only just saw this, because it’s been bugging me.
          #87681
          Grady Pruitt
            (was also looking for the inverted option that I remembered was in there… helps if I’m on the right drawing tool 😀 )
            #87682
            Paul Caggegi
              Update: this has since been fixed, and colors can be added as before.
              Re: inverted option – can you clarify? Do you mean flipping foreground/background colors like here:
              In which case there *is* a shortcut, but it doesn’t really work well, so the best thing to do is assign your own. Right-click on the two arrows in a circle, and assing/change chortcut to something that makes sense, but isn’t obviously something that Blender would use for another operation (eg: X)
              Or did you mean like, switching from draw to erase? In which case, this is actually easier – hold down CTRL while in draw, and it will switch to erase.
              #87683
              Grady Pruitt
                No.. I’d found it… I was talking about the inverted fill 😀 Once I switched to the fill bucket, I found it 😀
                #87684
                Paul Caggegi
                  Aaaaaah I see! Hahaha yes, it is a tool setting. Yes, this is both on the tool shelf, and under “Brush Settings” for the fill tool, yes. Unfortunately no shortcuts can be assigned to toggle AFAIK
                • The topic ‘blender palette colors do not save colors well in Blender 4.2’ is closed to new replies.
