Blender 5.1 doesn’t seem to have a “Guides” option
Forum Archive Blender 5.1 doesn’t seem to have a “Guides” option
  • #21580
    nickej
      Just that. I can activate Grid in the Grease Pencil dropdown, but there’s no “Circular” option. Nor is there such an option in the Viewport Overlays. Any suggestions?
      Other than that, I’m really enjoying these tutorials. Finally getting me over my confusion about Grease Pencil settings.
      #100321
      Dwayne Savage
        They rewrote grease pencil in 4.3. Guide hasn’t been added back in yet.
        #100322
        Dwayne Savage
          Sorry, I Misunderstood the the question. You can use the Circle tool in the toolbar to draw the circle. Note: you won’t have to close the gap or smooth out the points since circle tool does this automatically. Although you may want to play with the smoothing just because it’s such a useful tool.
          #100323
          Grady Pruitt
            Dwayne is actually right on both accounts… when grease pencil was rewritten, they took out the guides and, at least as of 5.1, they hadn’t put them back in yet (circular or otherwise). However, you can draw a circle using the circle tool. Use Shift to constrain it to a perfect circle. Or you can freehand draw a circle and connect the ends. I believe if the ends are connected, the tools will treat the ends as continuous, but if they’re not connected, the tools will (finally) treat them independently if you have connected only fall off enabled (meaning if you edit one end of a non-connected stroke, it will respect the fall off as long as the fall off doesn’t reach as far as the other end of the stroke). When I’m doing freehand, particularly if I’m doing the line art, I’ll use auto-smoothing so the line isn’t jaggy, but turn it way down to like 10 so it doesn’t lag as much.
          • The topic ‘Blender 5.1 doesn’t seem to have a “Guides” option’ is closed to new replies.
