Black and white rings not appearing on the ring
Forum Archive Black and white rings not appearing on the ring
  • #19830
    S S
      The noise texture and the nodes connected to it are somehow not working; the black and white rings are not showing up on the ring at all and I don’t know how to fix it. Any help would be appreciated!
      #93656
      S S
        Surpassing the mapping node altogether, and then rejoining them all again fixed it for some reason.. though I still don’t know what caused the problem in the first place
        #93657
          If you could post a Screenshot of your Shader Editor with the not-working Node setup, we might be able to tell what’s wrong.
          #93658
            It might be the origin point of the object, it might be the scale. The thing when working procedurally is that it depends on other things apart from the nodes themselves. So yes a couple of screenshots could help and try describing what you’re doing so we can try and spot the error.
            #93659
              My guess is it’s the Scale in the Mapping Node…
            • The topic ‘Black and white rings not appearing on the ring’ is closed to new replies.
