Big Bevel issue Press Start course
Forum Archive Big Bevel issue Press Start course
  • #16864
    Utopic Light
      Hello, I am writing here because I am stuck in the progress of the press start course..
      Here is my problem: when we have to add bevels on the ventilation holes at the back of the cartridge slot with the “mean bevel weight” function, it does not work and it cancels the bevels that I had made on the buttons (with “mean bevel weight” too and perfectly ok! ) earlier in the tutorial..
      I tried to understand and strangely, the ventilation holes on the right work, and all those that I highlighted (annotation)  on the attached photo cause the bug if I try to do the bevel!!
      I tried to not bevel these vents and to continue the tutorial but other attempts to bevel for example on the main faces cause the same thing…
      when I try to make individual bevels (without modifier) on each of the “problematic” edges, I strangely have no problem which makes me say that it may not come from a topology error? (which I did very carefully) is this a known bug with version 3.6?
      And as evidenced in the photo ( arrow )  I have purple vertices.. what does this mean?
      and finally, when I add a mesh like a simple plane, it is huge!!
      I changed the metric scale for centimeters in the scene section but this is requested in the tutorial..
      do you think you have an explanation about this too?
      I would like to point out that I can send you my .blend project if that helps you understand??
      Thank you in advance, wish you a good day.
      By the way: this tutorial is awesome!! never seen anything so high quality on youtube!! 🙂
      #81173
        See your other post.
      • The topic ‘Big Bevel issue Press Start course’ is closed to new replies.
