Bevels of console object is lost when speakers are joined.
Forum Archive Bevels of console object is lost when speakers are joined.
  • #20982
    Triston Sisney
      Hello all, at 16:15 in this video you select the speaker then shift-select the console and ctrl-j to join. When I Join these two objects in my file, all of the bevel is lost, leaving the original sharp edges. Attached are pictures of before and after join.Before Join.pngAfter Join.png
      #97868
        HiTriston @Swizzlekeys ,
        That is most likely because you have Clamp Overlap enabled. The Speakers are now probably causing the Clamping to kick in (or kick in earlier) making the Bevels of the Console smaller, so it might look like they are gone.
        #97869
          Also the order of the selection matters. If you select the speakers and then the console, it’s different if you first select the console and then the speakers. The order of selection will dictate which object absorbs which object.
          #97870
          Triston Sisney
            Thank you so much Martin! Solved Issue!
          • The topic ‘Bevels of console object is lost when speakers are joined.’ is closed to new replies.
