Beveling the split line is creating weird geometry?
Forum Archive Beveling the split line is creating weird geometry?
  • #19903
    Sam Edgar
      I’m trying to create the gap between the top and bottom casings and the bevel is not generating the same way. It’s only on next to the battery casing that it’s messing up. I’ve made sure there’s nothing else selected than the line.
      #93920
        Try the first two things that are most common, you have double vertices,so select everything with A and then M to merge by distance. And see if your scale is applied. Also check your normals are consistence.
        #93921
        Sam Edgar
          Yup daft me forgot to check the normals on the battery plate thanks!
          #93922
          Oussama Oucherif
            For me it  was the face orientation, so i had to recalculate outside Shift N
          • The topic ‘Beveling the split line is creating weird geometry?’ is closed to new replies.
