Bevel Tool at 17:20
Forum Archive Bevel Tool at 17:20
  • #16509
    Mark Terry
      Hey there, while beveling the 4-way fitting you were able to bevel the inner edges (they make an “X” around the fitting. For some reason, I am not able to do that on my end. I applied the scale and also tryed it with a modifier, but I had no luck. I’m sure its user error, but I can’t seem to correct it. Thanks!
      #79763
      Mark Terry
        Nvm, I did not merge verts by distance. It is now working.
        #79764
        Paul Whidborne
          In addition to this for anyone else having similar issues I had to increase the merge by distance radius for it to merge the centre vertices for some reason.  I also had a face orientation issue that prevented the bevel from working properly.   Took me a little while to work it out so thought I would share….NORMALS.png
          #79765
          Adrian Bellworthy
            Yes! If you started with a Mesh>Circle, the face direction depends on which direction you extrude the circle.
          • The topic ‘Bevel Tool at 17:20’ is closed to new replies.
