Bevel Problem
Forum Archive Bevel Problem
  • #17488
    Alexis Badillo
      Around 2:09 he beigns to bevel the corner of top corner of the console. When I try to bevel the two corners the tool activates but has no effect I have started over a few times and the problem persists. I am brand new and can not seem to figure it out.  I did apply the scale.
      #84069
        Hi Alexis @alexispb310 ,
        First do a ‘clean up’, because your failed attempts might have created some so-called double Vertices; Select all Vertices (with A) and then M > Merge > By Distance.
        Then make sure you have all 4 Vertices Selected:
        and CTRL+B to Bevel.
        If that doesn’t help, let us know, please.
        #84070
        Adrian Bellworthy
          TOP TIP:
          Use edge select when selecting multiple edges to bevel.
          Bevel is an edge tool, vertex select can sometimes mean unwanted edges can also be selected.
          #84071
            Another tip is when you select the edges or vertices, tap G and move them around, you’ll see instantly if there is something wrong if they behave weirdly or you have double vertices.
            #84072
            Alexis Badillo
              I Figured it out after taking a break last night the trick was to merge by distance. Thanks alot guys.
            • The topic ‘Bevel Problem’ is closed to new replies.
