Bevel not working right
Forum Archive Bevel not working right
Viewing 15 posts - 1 through 15 (of 16 total)
  • #11221
    product346
      At about the 16min mark. Trying to bevel where the cube.002 and cube 001 meet. When go into edit more and select a, it grabs both so when I bevel it, it goes in and doesn’t curve right.
      #52749
        Can you post before and after screenshots of what the bevel is doing to your mesh? Or better yet a GIF of the issue. I don’t quite understand what’s happening..
        #52750
        sprinklelicious
          Yeah I will in a few, Pretty much when I hit Ctrl b to bevel, it’s doing the edges, but making them sharp and not round like in your video. So if I were to bevel and click off, my corners are pointy. Give me a little bit and I’ll send a screenshot.
          #52751
            @sprinklelicious Ok that sounds like Profile setting in the bevel options is set to 1.0 and not 0.5 (default).
            #52752
            product346
              Here’s a picture.
              #52753
                @product346 What in tarnation…Can you provide a download link to your .blend file so I can take a closer look? The best way to do this is by uploading to dropbox, google drive, or equivalent file hosting service and copy + pasting a link.
                #52754
                product346
                  product346
                    I really don’t want to have to restart but I will if need be. Was going to last night but thought I should try for help first.
                    #52756
                      Hi product346!
                      I can’t see your .blend (access denied), but from your Screenshot i’d say that your Normals are not consistent.
                      A bevel (with one segment) is created by making a plane, perpendicular to the Normal. An Edge bevel makes it perpendicular to the Edge’s Normal. An Edge Normal is calculated as the ‘middle’ (angle-wise) of the Normals of the two adjacent Faces.
                      Here is what I think happened in your case:
                      There are three very important shortcuts, that you should use all the time:
                      SHIFT+N to recalculate your Normals (in Edit Mode with everything selected).
                      ALT+M > Merge by Distance (to remove double vertices).
                      And last but not least: CTRL+S to save your file!
                      #52757
                      sprinklelicious
                        I will try and re upload it when I get home. I’ll try what you said first though. Worst case I’ll restart. Could use the experience being it’s been a while since I’ve done this.
                        #52758
                          BTW. here’s another thing that can happen when your Normals are messed up (that’s why this is called abnormal behavior..).
                          https://blog.cgcookie.com/forums/topic/collab-2021-wip-duerer/
                          #52759
                          product346
                              You didn’t only have messed up Normals, but also double vertices:
                              Look at the number of Verts (bottom right). That should be16 (4 at each corner, it is only one ‘Cube’).
                              Select all and ALT+M, this will remove 40 Vertices and leave you with this:
                              Now use SHIFT+N to recalcluate the Normals (because they are not all blue) and you’re good to go. Bevel away:
                              #52761
                              sprinklelicious
                                When I do alt m it just deletes them
                                #52762
                                sprinklelicious
                                  Nevermind, got it. Thank you so much for the help.
                                • The topic ‘Bevel not working right’ is closed to new replies.
