Bevel MOdifier
Forum Archive Bevel MOdifier
Viewing 10 posts - 1 through 10 (of 10 total)
  • #19433
    xavier ortega
      My bevel modifier is not doing anything to my selected object.
      #92258
      xavier ortega
        I figured it out, I had to apply transformations first!!! Dhoo!!!
        #92259
          HI Xavier @xortega , good that you figured that out; it is important to (almost) always Apply the Scale.
          However, try to avoid Applying the Rotation and (almost) never Apply the Location. Please don’t get into the habit to Apply > All Transforms, instead of Apply > Scale, ‘just to be on the safe side’.
          #92260
          xavier ortega
            Got it, thank you! I think I ended up getting some funky things going on because of that. 4th time is the charm! Cheers all and happy holidays!
            #92261
            Sebastian Riezler
              I also had to uncheck “clamp overlap” in the Geometry section of the modifier for it to work.
              #92262
              xavier ortega
                Thank you, I think I might have had the select edge instead of vertex selected too, so it wansn’t showing up.
                #92263
                omar omera
                  hi , iam facing the same problem , tried what you all said and nothing happen , what should i do ?
                  #92264
                  xavier ortega
                    If you used modifier, try rearranging the order, sometimes that helps. I hope it works. If you already applied scale to all objects being manipulated, I would try that next.
                    #92265
                      HI Omar @omar4799 ,
                      Could you give us more context, please? A screenshot of the full UI might also help.
                      Clamp Overlap and not Applied Scale are indeed the most common issues, when the Bevel Modifier seems to do nothing, but it could be something completely different.
                      #92266
                      omar omera
                        thank you all i have managed to solve the issue after remake some bevels and tried again , it worked
                      • The topic ‘Bevel MOdifier’ is closed to new replies.
