bevel acting strange
Forum Archive bevel acting strange
  • #10138
    yukino hatake
      hello guys.
      working onto a pretty big project (creating a full house). Somehow my bevel act strange with certain edge’s  . this is how it looks .
      does anyone know what could be causing this ?
      #44532
      Thibaut Bourbon
        Hi @yukinoh1989 ,
        there’s different reasons why a bevel could misbehave, try checking the following:
        – did you apply Scale and Rotation on your object (Object mode, Ctrl + A > Apply Scale & Rotation)
        – check your normals (Edit mode > select all > Ctrl + N )
        – presence of doubles that need to removed.
        Regardless whether you use the bevel modifier or the ctrl+b tool, this first troubleshooting can solve your issue. If not, I’d be curious to know how it looks before it get bevelled.
        Good luck and hope that helps!
        /Thibaut.
        #44533
        yukino hatake
          @tbrbn thank you . indeed those 3 options helped . i do wonder now i have the door . and the frame of it .
          there is 1mm difference in all 3 sides of the door compared to the frame (left right and top side)
          is there a way to make it so it snaps to it but stay away like 1 mm of those sides or isnt this possible to do ?
          i kinda want to make it realistic (still need to add the some things like hinge and door handle (hope i have it correctly ) otherwise blame google translate xD  )
        • The topic ‘bevel acting strange’ is closed to new replies.
