Best way to create stone bricks for inside walls of a prison
Forum Archive Best way to create stone bricks for inside walls of a prison
  • #9568
    louis1lal
      Hi,
      I try to model the inside of an old style prison cell and I am wondering what would be the best and clean way to model the bricks for walls. Would it be better to model them one by one or is there a particular workflow that is good for that?
      Thanks,
      #34586
      silentheart00
        You could model one, then use the array modifier to build blocks quickly, or you could take a big plane and add displacement maps to give the illusion of a brick wall.  Depends on what you want to do.  For a game?  Definitely do maps.  For things other than a game?  A big stack of blocks could work.
        Anyone else have other suggestions?
        #34587
        William Miller
          Use a texture.
          #34588
          louis1lal
            Ok Thanks! I will try model them since it is for a pretty high res art picture.
          • The topic ‘Best way to create stone bricks for inside walls of a prison’ is closed to new replies.
