Benefits of “Specular Workflow” versus “Metalness Workflow”?
Forum Archive Benefits of “Specular Workflow” versus “Metalness Workflow”?
  • #12641
    Ingmar Franz
      What are the benefits of a “Specular Workflow” (not in Blender-Cylces) compared to Blender’s “Metalness Workflow” in Cylcles?
      #59978
      Jonathan Lampel
        The only benefit I know of is that it gives you control over the reflectivity, but the specular slider on the Principled BSDF in Blender makes up for this.
        #59979
        Ingmar Franz
          Can I say that the “Specular” value of the “Principled BSDF” shader node defines the strength of the highlights whereas the “Roughness” setting defines the sharpness of the highlights?
          #59980
          Jonathan Lampel
            Yes! And if you want to get technical it’s really the IOR.
            #59981
            Ingmar Franz
              When it comes to the Fresnel effect and its connection with the roughness, a higher “Roughness” value not only softens the highlights but also reduces the Fresnel which looks to me somehow as a special case of a highlight.
            • The topic ‘Benefits of “Specular Workflow” versus “Metalness Workflow”?’ is closed to new replies.
