Bcity, i need the walls to work with “not uniform” transforms
Forum Archive Bcity, i need the walls to work with “not uniform” transforms
  • #20634
    Angel M
      So basically, for the walls assets, i need to have a few that aren’t completely “squared/uniform”,
      this:
      if i scale them how i want they would just clip, it’d also be great if only some walls can be non uniform, so there can be a mix of bigger/wider walls/first floors and the normal ones, what happens is here
      they clip.
      #96658
        Hi Angel @Angel90 ,
        That would probably require a drastically different workflow, depending on how much you would break the dimension of the assets; if you have evrything 3×3 and a few 6×3 for instance, you might be able to adapt the process (not saying that that would be simple though).
        Otherwise, you might need to Instance them on the Curves and then somehow add floors on top of that.
        This Tutorial might give you some useful ideas: https://www.youtube.com/watch?v=XFbD3rqE1eM&list=PLVm7O9OzjT6EIDtFGC67QxGsHkz3_RbIw&index=26
      • The topic ‘Bcity, i need the walls to work with “not uniform” transforms’ is closed to new replies.
