Auto smooth not available
Forum Archive Auto smooth not available
  • #18045
    Paul Whidborne
      So auto smooth isn’t available in 4.1 and unfortunately the bevel on the four directional piece is showing the sharp top edge (I’ll link an image in a reply). I’ve tried shade smooth and shade smooth by angle but neither work to round out this edge. Is there a way to do it without auto smooth? Regards
      #86356
      Paul Whidborne
        #86357
          HI Paul,
          Shade Smooth by Angle is more or less the same as Auto Smooth, but you’ll have to adjust the Angle immediately after Shade Auto Smooth (Adjust Last Operation Panel, also available with F9).
          Or use the Modifier: Normals > Smooth by Angle.
          #86358
          Adrian Bellworthy
            Yes, but don’t use the Shade Smooth By Angle option…
            Use Shade Smooth and then add the Smooth by Angle modifier, this modifier basically replaces the auto smooth option that was in the data properties.
            #86359
            Adrian Bellworthy
              Shade Smooth By Angle adds sharp edges to the mesh. It’s certainly not ideal IMO.
              #86360
              Paul Whidborne
                Thanks both, adjusting the angle after smoothing by angle worked perfect (had missed that).  Will also check out the modifiers and see what results they give.  Appreciated as always.
                #86361
                  True Adrian! (The Modifier does that as well, but not destructively.)
                  In 4.2 this will probably be changed:
                  Shade Smooth by Angle will be removed. In its place will be Shade Auto Smooth (as it is called now, name may change) and that just adds a Shade Smooth by Angle Modifier to the Mesh.
                • The topic ‘Auto smooth not available’ is closed to new replies.
