At 3:53 when attempting to move the ground plane
Forum Archive At 3:53 when attempting to move the ground plane
  • #15956
    Juan Hernandez
      At 3:53 when attempting to move the ground plane I can not move it through the camera view. The back of the plane goes down while the front remains fixated.
      #77642
        Kenan is not moving the ground plane (you want the ground plane to stay on the 3D ‘ground’) there, he is moving the Camera up (G, Z with the Camera selected) and rotating it a bit (with R) to fit the footage.
        When the back of the plane goes down and the front stays, then you are rotating it (on the X-axis if your scene is set up the same as in the tutorial).
      • The topic ‘At 3:53 when attempting to move the ground plane’ is closed to new replies.
