Array rotation
Forum Archive Array rotation
  • #16073
    Tj sherry
      When I enable my object offset and add in my array rotation object, the ten arrays get displaced on the negative z-axis. How do I ensure they maintain their original position as I tweak the array rotation?
      #78071
        Hi @Tj ,
        Make sure that you only have Object Offset enabled and that your (Arrayed) Object’s Origin is in the same Location as your Empty (or whatever Object you use as an Offset for the Array).
      • The topic ‘Array rotation’ is closed to new replies.
