Array Modifier on Object
Forum Archive Array Modifier on Object
  • #9810
    mondral
      Hello
      I’ve been working on this little Robot for a while. The main detials are almost done. Now I wanted to add something like rivets around the head of the character, to give it a more mechanical look.
      I tried doing it with a curve -> I took a vertical Edgeloop – scaled it to 0 on the Y-axis – placed it in the middle – tried adding an Array + a Curve modifier to the rivet, but I got really weird results.
      I also tried the 2 approaches to do so from the Course “Introduction to Hard Surface Modeling”. They are explained in the last Video “Modeling Rivets & Final Polish”, if you want to look them up.
      It doesn’t matter what I try, I just can’t get my desired result.
      This is the Character & also the Reference Image. It should look like this +/-
      If anybody manages to solve the problem, I would be happy if he/she could explain how he/she managed to do it, thanks alot!
      Have a nice day.
      #37488
      Ronald Vermeij
        Youtube is your best friend in finding out how to exactly use and tweak the Array Modifier. Start here:
        https://www.youtube.com/results?search_query=blender+array+modifier
        #37489
        Thibaut Bourbon
          Hey @mondral
          You need to make sure the origin of your rivets and your curves are matching:
          You might also play with the curve modifier’s deformation axis. Hope that helps!
          Cheers,
          /Thibaut.
        • The topic ‘Array Modifier on Object’ is closed to new replies.
