Are we supposed to stick to painting? Wanted to try baking normal maps w/ multi-res.
Forum Archive Are we supposed to stick to painting? Wanted to try baking normal maps w/ multi-res.
  • #6549
    vexoul
      I notice the UI we are given is lacking the outliner and properties viewports – are we meant to just stick to painting?
      I thought I might try out the multi-resolution modifier and bake a normal / displacement map from it if we were allowed to.
      Thanks!
      #25561
      Jonathan Lampel
        Hey @vexoul , sounds like a great experiment! You’re welcome to do that as well if you’d like, but the diffuse does need to be painted by hand. Normal / bump maps can sometimes be used to hide flaws in the painted texture, so just be extra sure you’re not using it as a crutch. Looking forward to seeing your result!
      • The topic ‘Are we supposed to stick to painting? Wanted to try baking normal maps w/ multi-res.’ is closed to new replies.
