Are these courses meant to be done in order?
Forum Archive Are these courses meant to be done in order?
  • #18451
    Nicholas Britton
      the courses seem to be out of order if so.
      #88106
        Hi @insane ,
        I’d say the order isn’t strict; my suggestion would be to keep Mesh Modeling, Lighting, Materials and Shading and Texturing in that order, but the rest , you can do anytime…meaning also somewhere  in between those 4…
        This is just my personal opinion!
        #88107
        Lindsey LaCombe
          Hello!
          I’ve just started a couple of weeks ago and I haven’t been taking the courses in order at all. Sometimes I’ll even be taking two at one time. I would say it kind of depends on the level your at skill wise. For example, I had never used blender before. I had used other software like Maya though. I started with blender basics, then moved on to some of the animation stuff, and took some of the modeling courses at the same time. I think it really just depends on what you want to do and what skill level your at! But that’s just me! Hope that helped!
          #88108
            I agree with Martin as well as Lindsey’s advice. It will depend on your goal, but usually the order that Martin suggested is the way to go, unless you have a very specific target, like you just want to do animation specifically. But even then I’d say know the very basics of the other disciplines as well.
            #88109
            Jonathan Lazaro
              look in the playlists,  i used that for awhile till i started understanding what i could do next
              #88110
              Adrian Bellworthy
                The CORE courses are set out in the best order to learn each stage.
                If for example you are not interested in animation, you don’t need to complete all the courses.
                However,
                It is advisable to understand rigging, animation, etc., etc., because as a modeler you will need to understand the needs of a rigger and animator to supply a model in the condition required for rigging and animating.
                Also, you will have a fuller more rounded understanding of Blender if you follow all the CORE courses.
                You don’t necessarily need to pursue animation any further if you don’t wish to.
                It is totally your choice.
              • The topic ‘Are these courses meant to be done in order?’ is closed to new replies.
