applying the pose to the magazine from pose library does nothing :(
Forum Archive applying the pose to the magazine from pose library does nothing :(
  • #14121
    Serg
      applying the pose to the magazine from pose library does nothing 🙁
      dont understand why.
      I select all bones and create pose library for the weapon but then when trying to apply the pose after transforms it only works for the root bone and not for the magazine
      #69315
      Jonathan Lampel
        Hey Sergey, could you share the file somehow? I’m not sure off the top of my head but I could look at it for you.
        #69316
        Serg
          Hey Jonathan,
          Here is the rig I made https://1drv.ms/u/s!Autbo5KRI6xKhLwK1fXw8tJixeTolA?e=bG1FrN
          it is a7zip file with a blender file inside
          passwoord is cgcookie
          #69317
          Jonathan Lampel
            Ok, short answer is… I have no idea. This looks like a bug! I can’t get it to work as expected. I think it’s worth reporting to the developers.
            There is a workaround though. Head to the action editor and choose your pose library as the action you’re viewing. Each pose is associated with a keyframe. The first pose in the list is the first keyframe, the second is the second keyframe, etc. If you manually insert the keyframes on the proper keys, the Apply Pose button in the pose library will work again. So, the bug must have to do with the Add Pose operator not respecting all of the bones. I can’t find any reason why it’s not.
            If I try to use the pose library in a new file with a fresh rig, however, the library works as expected.
            Oh and nice model BTW 🙂
            #69318
            Adrian Bellworthy
              What version of Blender did you use to create it? If it’s 2.92 that might be the problem. I have seen lots of people having issues with animations when created with the buggy 2.92.
              #69319
              Serg
                jup 2.92
                I am getting rid of 2.92 and will install the new one
              • The topic ‘applying the pose to the magazine from pose library does nothing :(’ is closed to new replies.
