Applying Set Inverse, Clear Inverse and Set Inverse again to fix the position of the right hand
Forum Archive Applying Set Inverse, Clear Inverse and Set Inverse again to fix the position of the right hand
  • #15061
    Deepak Jai
      Hi @jlampel, between 3:15 – 3:25, you fixed the position of the right hand by applying  Set Inverse, Clear Inverse, and Set Inverse again and the right hand magically snapped into the right position. I would like to know the rationale behind this because I prefer to do such operations deterministically as opposed to trial and error. Could you please elaborate on what is happening when I do those steps.
      #74102
      Jonathan Lampel
        Sure, so we had clicked set inverse at some point in the other file but not this one, so that’s why there was a difference. An inverse was automatically applied when the constraint was created, and that old data was still hanging around in this file. I don’t think the first Set Inverse click was necessary – just clear the old data, set it again, and you should be good to go!
        #74103
        Deepak Jai
          hmm, I kind of get it but I guess I’ll have take another look at it. Thank you
        • The topic ‘Applying Set Inverse, Clear Inverse and Set Inverse again to fix the position of the right hand’ is closed to new replies.
