Answer to why the spot lamp shines outside of the lamp-post.
Forum Archive Answer to why the spot lamp shines outside of the lamp-post.
  • #17479
    Yves Perera
      I’d like to answer your question regarding the fact that the spot lamp can emit light outside of the lamp-post although it’s inside. Instead of changing the “Clip Start” you should go and play with the lamp “Radius”. If the radius is larger than the walls that are containing the lamp, then it will shine outside.
      #84033
        Oh yes, of course @shinsaku , that makes so much sense!
        Thanks a lot Yves for pointing that out 👍🏻
        #84034
          Excellent tip, Yves. Great timing too because I’ve been exploring this with my current project. You’ve confirmed what I’ve been suspecting. Thank you!
          #84035
          Eric Szabo
            Great tip! My default radius was set to zero. Wondering why light wasn’t working. This cleared it right up! Thanks!
          • The topic ‘Answer to why the spot lamp shines outside of the lamp-post.’ is closed to new replies.
