Anisotropic Shader Missing
Forum Archive Anisotropic Shader Missing
  • #17215
    Stephan Jeanpierre
      I’m in Blender 4.0 and this shader doesn’t appear in the shaders menu at all, even if I search.
      #82860
      Stephan Jeanpierre
        There is a slider within the Glossy BSDF shader though… Is that the same thing? Did they combine it for simplicity rather than having a whole separate node?
        #82861
        Sascha Feider
          “The Glossy and Anisotropic BSDF were merged into a single Glossy BSDF with anisotropy control. When opening files saved in 4.0 in older versions, all “Glossy BSDF” nodes will show up as Anisotropic BSDF nodes.”
          It’s been merged to declutter the whole menu. So you’re right on track 🙂
        • The topic ‘Anisotropic Shader Missing’ is closed to new replies.
