Animation Playback in Viewport slower?: Going from 2.92 to 2.93
Forum Archive Animation Playback in Viewport slower?: Going from 2.92 to 2.93
  • #14069
    Phil Osterbauer
      Has anyone noticed a drastic fps slow down in the 3d viewport when playing an animation? I was getting 24fps playback on 2.92 but when I moved to 2.93 I can’t get much more than 8fps in the same scene.
      #69029
      Adrian Bellworthy
        Hey @phoenix4690 ,
        That’s a pretty significant drop in fps.
        I have been munching my way through the animation cookies, I can’t say I’ve noticed a difference, however the scenes are not very complex.
        Perhaps @waylow would have a few tips to help.
        #69030
        Wayne Dixon
          Hi Phil,
          I haven’t noticed an issue but there were big changes to certain things in 2.93
          Python and the api changed, so some scripts and python related stuff will break or possibly run slow(?)
          You will also get warnings if you try to open a 2.93 file in a lower version.  (“Built with a newer Binary blah blah blah”)
          Here’s a couple questions to help you dig into the issue
          Is it the same scene in both versions (and are you running simplify on one and not the other)
          Can you find what is slowing it down.  (a specific mesh or prop or whatever)
          If you hide it, does it speed up.
          Maybe something is corrupted in that file, if you import everything to a fresh scene is the problem gone?
          I have a suspicion that it’s probably a setting that was introduced and it “on by default” in the newer version, but that setting didn’t exist in the older version.
          It’s not quite the same thing but when they moved the “show color groups” from the GE and Action editor into the user preferences I lost an hour or so trying to research where that setting went haha.
          Hope you figure it out!
        • The topic ‘Animation Playback in Viewport slower?: Going from 2.92 to 2.93’ is closed to new replies.
