animation attempt caused many questions (camera, weight painting, lighting ……)
Forum Archive animation attempt caused many questions (camera, weight painting, lighting ……)
  • #10180
    tanya
      A year ago was getting old, could feel the brain cells atrophying, decided to learn something totally new.  After year of tutorials and classes decided to try to put a nano-animation together and revealed massive holes in what I know.  I was hoping someone could point me to some tutorials that might answer some of them since I am trying to do another simple animation for January.
      1. I know the rolling snowman animation is bad, made some poor decisions early on.  The question is,  there is a shape key path created that you can’t see  it in the rendered or material view, but can in the other views.  How do I know if it is the lighting, camera,  etc. causing the problem?  Could I have used dynamic paint with displacement?
      2. How do you light a moving animation?  Also the amount of brightness is different if I look at it on my laptop vs a monitor, how do you know which one is correct?  The color also varies some but not a big deal,
      3.  Cameras, know nothing.  So I would like to learn not only about lens, focal length, etc.  but also about what camera angles are the best.  I sort of just guessed.  The cameras all use armatures, so anything on how better use the armatures.
      4. Weight painting for the armature.  I get weight painting, how do I figure out how vertexes should be weighted best.  The bear weighting is not the best.  I used the automatic weighting which worked ok, but a few bones were pretty bad, assume it had something to do with the mesh design.
      5. Animating facial features, both how to animate them and how to create a mesh so that it is possible.  Do I want to use shape keys or bones?
      6. Motion blur
      7. What could I have used compositing for?
      8. Last one, I baked all the particle systems.  Could I have baked anything else.
      Thanks,
      #44861
      yukino hatake
        Hello sadly I cannot help yet. But I do can say that it’s a good start. Of course some points could possible be better but I believe for you’re first this sure is a good start.
        Hope some people will be able to help you out with the questions
        #44862
        John Sanderson
          Don’t know if you’ve seen this tutorial already, but it’s a pretty good setup for cameras in animations like this one:
          #44863
          Char Hunter
            👋😃 @tanya53 ,
            I don’t know much about animation either.   @theluthier  has just posted,
            a few days ago, a course on rendering and finishing an animation.
            Rendering & Finishing a Blender Animation, maybe this can help you?
          • The topic ‘animation attempt caused many questions (camera, weight painting, lighting ……)’ is closed to new replies.
