Alt+S to thicken the curved portion of the lid is acting differently in 2.90.1 than in video
Forum Archive Alt+S to thicken the curved portion of the lid is acting differently in 2.90.1 than in video
  • #13028
    clydefrog
      When I do this, the mesh extrudes evenly to either  side of the faces instead  of to inside or outside. Is there a setting or toggle to change this?
      #61393
        The thing is, you have too much selected!
        This is how it should be. Look at the white dots (selected, in your case: orange) and the black dots (unselected):
        Now this happens when scaling (as it should):
        But you must have Extruded, canceled (which doesn’t cancel the extrusion, only the ‘Move” that would normally follow the Extrude) and then selected ‘everything’ and extruded again:
        Look at all the white dots (selected Faces). When Scaling now, this happens:
        #61394
        clydefrog
          Thanks for the help! I was using L to select all of the faces instead of selectin all.
          #61395
            That shouldn’t be the issue, you have double vertices in your screenshot ( more than one vertex at the same position), which can be seen by the black dots at the edges; they are the centers of Faces, You should use A, M > Merge by Distance! (I recommend you do this even if things appear to be working correctly now.)
            In fact: double vertices (solution : M > Merge by Distance) and flipped Normals (solution SHIFT+N) are together responsible for (a lot) more than 90% of all modelling issues.
            #61396
            clydefrog
              Thanks again, got it working now 😉
            • The topic ‘Alt+S to thicken the curved portion of the lid is acting differently in 2.90.1 than in video’ is closed to new replies.
