Alt-click does not disable all modifier (2.9)
Forum Archive Alt-click does not disable all modifier (2.9)
Viewing 10 posts - 1 through 10 (of 10 total)
  • #12715
    coyo
      SOLUTION: Disabling “Emulate 3 Button Mouse” in Preferences re-enables the ability to use the Copy to Selected alt-click shortcut.
      I tried doing the select all, then alt-clicking the “display modifier in viewport” icon and it does nothing. I’m using 2.9 and actually using Kent’s file from the downloads since I wanted to skip ahead to the UV unwrapping bit.
      Am I doing something wrong or was this behavior changed in 2.9?
      #60271
      Karen Trevino
        try ctrl L it brings up Linked data, choose modifiers
        #60272
        coyo
          Hi Karen, thanks for your reply. Ctrl-L gives one the option to link modifiers. That’s not what I’m doing. At that part of the video Kent selects all and then, by alt-clicking the “display modifier in viewport” icon in the mirror modifier, is able to disable that option for all selected objects with a mirror modifier. Currently, that’s not the behavior I’m getting with (as far as I can tell) the same process.
          #60273
          Karen Trevino
            Sorry I should say you remove the modifier off off 1.  then select the others and with the original with no modifiers on it as the “active” then press ctrl L and choose modifiers. it will make the others the same.  You add or remove the same way.
            #60274
            coyo
              I can remove them that way but I just want to disable them temporarily. Unless I’m missing something?
              #60275
              Karen Trevino
                Disable on the active mesh and it will disable all of them using ctrl L
                #60276
                coyo
                  While I still don’t know what happened to the ALT-click shortcut in 2.9 I have discovered how to accomplish the same thing via menus.
                  • Select all, and then make an object with the modifier you wish to toggle the active object, as shown in the video.
                  • Toggle the Viewport Display icon.
                  • Right-click and choose “Copy from Selected” from the resulting menu.
                  This copies the toggle status to any selected object with the modifier without applying or otherwise modifying data on objects that don’t.
                  #60277
                  coyo
                    SOLUTION
                    The culprit seems to be “Emulate 3 Button Mouse” but since I need to use that to make Blender and my Cintiq play nice together I will have to use the right-click menu and Copy to Selected instead.
                    #60278
                      Thanks for troubleshooting this and sharing your discovery 🙇‍♂️
                      #60279
                      coyo
                        Now that Blender automatically transfers settings to new versions I tend to forget to check those when troubleshooting. It would have taken me a much shorter time to have sorted things out if I’d remembered straight off. I really need to keep a “Blender journal” and check it at times like this!
                      • The topic ‘Alt-click does not disable all modifier (2.9)’ is closed to new replies.
