Forum Archive › Also texture bake is not working: black
Hey all! I haven’t been able to get this to work, my texture also turns out all black, even though the rest of the tutorial worked fine and I could get the results I wanted. Here is a link to the blend:https://drive.google.com/file/d/1YHLUTpmJmWBJGatI-rsExgfNMMft1Eq0/view?usp=sharing
Hi @popingblues – I ran through the process with your file and everything worked as expected for me. It’s a fairly specific process where it’s easy to miss a step or two. I recommend trying again, making sure to follow each of those steps carefully.
I had the same problem. I found that reducing the tile size to 4096×4096 corrected the issue.
