Also, if I don't have the light selected it disappears from view and I can only select it from the hierarchy window, it a…
Forum Archive Also, if I don't have the light selected it disappears from view and I can only select it from the hierarchy window, it a…
  • #4600
    resin213
      Also, if I don’t have the light selected it disappears from view and I can only select it from the hierarchy window, it also seems much smaller compared to the one in the video, yet my car scale is 1,1,1. I’m not sure what is going on or if it something to do with the way my scene is set up.
      #22827
      Jonathan Gonzalez
        It’s hard to understand what’s going on in your scene. I’d recommend testing this out in a new scene. The scale of the light won’t really do anything. If you want to adjust the intensity or range of the light it’ll all be done within the light component.
      • The topic ‘Also, if I don't have the light selected it disappears from view and I can only select it from the hierarchy window, it a…’ is closed to new replies.
