Add on does not appear in the node menu after installing
Forum Archive Add on does not appear in the node menu after installing
  • #14062
    emilie7731
      I made sure to install propertly but doesnt appear in the Node menu of Shader Editor – although I can see Voronoi Scatter & Un-scatter as greyed out options when I right clic, can you help?
      #68999
      Jonathan Lampel
        The Node menu is pretty long, so it may just be that you need to scroll to the end? Since it’s not super convenient I like to add it to my quick favorites by right clicking on it in the menu, so that way it appears in my Q menu.
        Using it via the right click context menu will not give you the popup with the options (I think it’s a Blender limitation) and it will resort to using the defaults.
        If  Voronoi Scatter is greyed out then you just need to select some image textures first. If Un-Scatter is greyed out then you just need to select a scatter node once one has been created.
        Hope that helps!
        #69000
        emilie7731
          Thanks for your help:)
        • The topic ‘Add on does not appear in the node menu after installing’ is closed to new replies.
