About the paws, is there any other alternative for Cx5? Would a hard oil clay be enough to withstand the sculpture's weigh…
Forum Archive About the paws, is there any other alternative for Cx5? Would a hard oil clay be enough to withstand the sculpture's weigh…
  • #3845
    Victor Ferraz
      About the paws, is there any other alternative for Cx5? Would a hard oil clay be enough to withstand the sculpture’s weight?
      Cx5 is not avaliable in Brazil and to order it internationally would take several months 🙁
      PS.:Sorry for the previous “question”. I was not aware that pressing “enter” would send the text without letting me format it.
      Thanks in advance,
      Victor Ferraz.
      #21787
      Lisa Schindler
        Hey Victor! Of course, you can use whichever material you want. What you may want to do though, is to add a rudimentary armature for the feet as well, like a simple “hand” made of wire. Just so your claws won’t break off and have a bit of support.
        With an underlying armature you can also continue to use Monster Clay (or whichever clay you’re using). The armature lends the support CX5 doesn’t need because it can support itself.
        If you’re interested, you may want to check out Chavant’s “Castilene” medium or hard if that’s available in Brazil (http://www.castilene.com). It is similar to CX5, though a tad softer. But it still doesn’t need an underlying armature.
        Let me know if you have more questions! 🙂
        ~Lisa
      • The topic ‘About the paws, is there any other alternative for Cx5? Would a hard oil clay be enough to withstand the sculpture's weigh…’ is closed to new replies.
