A note with Blender 4.3 on the cylinderical solidify step yielding non-manifold geometry
Forum Archive A note with Blender 4.3 on the cylinderical solidify step yielding non-manifold geometry
  • #20309
    Dano Wils
      If anyone else runs into this, you may be able to fix it with setting Mode to ‘Complex’, which seems to have been added somewhere along the way. I was getting some weird non-manifold geometry after the solidify modifier step (though Extrude worked fine), and setting the Mode seems to have resolved it.
      #95455
        Hi Dano,
        I am not sure what you mean here; It sounds like you are saying that a Solidify Modifier resulted in non-Manifold Geometry. If that is the case, I’d suspect that you have some Mesh problems, that would need to be fixed.
        #95456
          Can you post some screenshots?
        • The topic ‘A note with Blender 4.3 on the cylinderical solidify step yielding non-manifold geometry’ is closed to new replies.
