9:35 Can’t set keyframe in the graph editor
Forum Archive 9:35 Can’t set keyframe in the graph editor
  • #14774
    Christian Pohrer
      Video time: 9:35
      Hello,
      somehow I can’t add keyframes with ctrl left click. I’m using Blender 3.0.1.
      Did they change the shortcut? I can’t find it.
      Kind regards
      Christian
      #72790
      Wayne Dixon
        No that still works, you just need to make sure the channel is active (and visible) on the left hand side.
        I’m talking about next to the eyeballs, not in the graph part.
        Hope that sorts it out for you.
        #72791
        Christian Pohrer
          Hey thanks for the quick answer. 🙂
          I think everything is visible here. I tried to reset the preferences but that didn’t work either.
          #72792
          Adrian Bellworthy
             The shortcut you are after is CTRL+RightClick
            #72793
              When you are a left click selecter, then it is like @adrian2301 says, CTRL+RMB.
              But remember that @waylow uses right click select (while that is superior) and then the shortcut is CTRL+LMB
              #72794
              Christian Pohrer
                omg thank you all yeah it was right clilck. Thanks 😀
                #72795
                Wayne Dixon
                  Oh dear, my bad.
                  Yes I forgot that left and right is flipped, when you live in the other hemisphere…..I mean, when you use right click select.
                • The topic ‘9:35 Can’t set keyframe in the graph editor’ is closed to new replies.
