8:00 I can’t see the curves on the graph editor
Forum Archive 8:00 I can’t see the curves on the graph editor
  • #16481
    erikitect
      So as I said in my previous post I back tracked to creating my first node with keyframes again.
      It works but I can’t see the curves on the graph editor now. How do I make them visible?
      #79641
      erikitect
        I don’t need help with this question any more. I figured it out.
        #79642
        Dwayne Savage
          Do you have the node with the keyframes selected?
          #79643
            What was it in the end? Just so if other people are having the same issue and they see this question, they can find an answer to their problems.
            #79644
            Neale Genereux
              I ran into this exact problem. Turns out I had the node selected in the shader editor, but I did not have the plane object selected in the scene. Took an embarrassing amount of time to figure that one out 🙂
              #79645
              Oscar Gomez
                This answer helped me out too.  Was pulling my hair for several minutes on why I could not see the nodes.
              • The topic ‘8:00 I can’t see the curves on the graph editor’ is closed to new replies.
