@6:05 "Join UV's" is no longer an option in 2.78. It is now "transfer UV's" and furthermore, the geometry bus be exact mat…
Forum Archive @6:05 "Join UV's" is no longer an option in 2.78. It is now "transfer UV's" and furthermore, the geometry bus be exact mat…
  • #5112
    David Frazier
      @6:05 “Join UV’s” is no longer an option in 2.78. It is now “transfer UV’s” and furthermore, the geometry bus be exact matches now in order for control-L-transfer-UV’s to even work right. Never had this problem before. Very confused!
      #23473
        I’m pretty sure geometry has always needed to be identical for transferring UV’s to work. It’d have to be super robust for it not to require identical geo..
        #23474
        David Frazier
          Got it bro! Thanks. But Kent, you ALWAYS do super robust work… haha!
          #23475
          David Frazier
            My geometry is not the same on all the toes. I did line up the UV’s on top of each other and then snap the borders like you did, but is the non uniformity going to cause problems when I paint the textures?
          • The topic ‘@6:05 "Join UV's" is no longer an option in 2.78. It is now "transfer UV's" and furthermore, the geometry bus be exact mat…’ is closed to new replies.
