5 subdivisions man
Forum Archive 5 subdivisions man
  • #6514
    option
      it got hard to keep my mesh straight by the time i was at 5 subdivisions. especially the crease brush. it also seemed to work opposite  of what was intended, even in the same stroke sometimes. like from concave to convex. suggestions?
      #25502
      Jonathan Lampel
        Hmm, if it’s doing the opposite double check that the brush hasn’t been switched from subtract to add. Another possibility of inverted sculpting is if the normals are inverted, which can be fixed by recalculating normals in edit mode.
        #25503
        option
          thanks. ive moved onto boots. im trying to power through that one. attention span strained. good series. ill check into your suggestion later though.
        • The topic ‘5 subdivisions man’ is closed to new replies.
