2.8 adjustments?
Forum Archive 2.8 adjustments?
Viewing 12 posts - 1 through 12 (of 12 total)
  • #11597
    midnightsmack
      Hey there, sorry if I’m late on this. I’m trying to get the mean-bevel weight method to work in Blender 2.83, but it seems that nothing happens when I add the mean bevel weight in the transform menu. I’m using weight and have tried with both Offset and Width. Obviously Bevel is different in this version. Any way you can translate how to get this to work for 2.83?
      Blend file if you need it: http://pasteall.org/blend/index.php?id=53111
      #55431
        CTRL+E > Edge Bevel Weight:
        #55432
        midnightsmack
          Thank you so much for the quick response!
          #55433
          midnightsmack
            Hey apologies, but I’m having the same issue. Once I tab out of edit mode all the bevels dissapear.
            #55434
              That’s strange! It works when I try it:
              I’ve tested it in 2.82a and 2.83.11. Both work the same.
              #55435
              midnightsmack
                That is bizarre. I’m using the most recent version of Blender. Any chance you could paste that one back and I can see whats going on? Would love to progress this one, it’s a great tutorial.
                And you’re not applying anything before you tab out of edit mode? It seems odd that they just dissapear.
                #55436
                  https://drive.google.com/open?id=1fbBveOn4RJm4dai-zKHwspgIG9iTkT75
                  This is what you should see:
                  Just added the Bevel Modifier to the selected piece, nothing applied or anything. Latest build (from about one hour ago…), but same result with 2.82a. I’m using Linux btw.
                  #55437
                  midnightsmack
                    Thank you for your continued help. After opening your file I do see the bevel on the piece you did, but no bevel whatsoever is happening on the main body piece. After a lot of investigation I see this:
                    Any clue whats going on there? This is with clamp off, when I turn it on everything goes fully flat again.
                    #55438
                    midnightsmack
                      Comparison of EDIT mode vs OBJECT mode
                      EDIT:
                      OBJECT:
                      Very lost here. Vertex mode works.
                      #55439
                        I’m not exactly sure what is happening, but,  the version I have lying around suffers from a severe case of impossible geometry, with overlapping faces and inner faces and crossing edges. I don’t know if that’s what is causing this, but it is definitely not helping!
                        You will have to clean that up first! (In a case like this, I’d re-model that part completely, but that’s up to you…)
                        If you have a clean version and the Bevel is still not working, post a new link and I will have a look.
                        #55440
                        midnightsmack
                          I’m noticing this now myself. I definitely bit off more than I could chew by starting with this one. Thanks for bearing with me, I appreciate the quick and helpful responses.
                          #55441
                          michaelmoore
                            I’m not exactly sure what is happening, but,  the version I have lying around suffers from a severe case of impossible geometry, with overlapping faces and inner faces and crossing edges. I don’t know if that’s what is causing this, but it is definitely not helping! <a href=”https://detecthistory.com/top-metal-detectors/ “>
                            </a>
                            I have a modified version and Bevel is still working lol
                          • The topic ‘2.8 adjustments?’ is closed to new replies.
