14″14 all disks are separate objects but you need to merge them into one.
Forum Archive 14″14 all disks are separate objects but you need to merge them into one.
  • #16549
    erikitect
      At 14:14 you select all the circles that are part of the cloud and delete the faces. I am not on the same page as you at that moment because all my circles are separate objects and they need to be one object. How do I do that?
      #79954
        In Object Mode, with all Circles selected, press CTRL+J to join them into one Object.
        #79955
          Keep in mind that Kent duplicated the circles inside edit mode, which makes them part of the same mesh object, they remain contained as part of the same mesh when you do it in edit mode. You probably at some point went into object mode as you duplicated them and that made them each one their own object.
        • The topic ‘14″14 all disks are separate objects but you need to merge them into one.’ is closed to new replies.
