Reply To: Worth changing settings so 1mm = 1mm?
Forum Archive Worth changing settings so 1mm = 1mm? Reply To: Worth changing settings so 1mm = 1mm?
#83014
Porter Nielsen
    I agree with Omar, that changing the units can make things wonky; but an additional reason to be careful when changing the units is if you ever intend to share or distribute blend files with others.
